d119
Since a lot of this stuff is CHP-specific, or designed as a result of CHP demand, I wouldn't be surprised if they are paying through the nose for it so that manufacturers can recover development costs.
I'm also interested in the "$6,000 mobile repeater" listed.
That's the 700 MHz VRS system, that's actually not a bad price from that system. I'm not sure why they can't reuse the one already in the vehicles though. They may be somewhat old but they are not so old that they should need to be replaced.
Are the NX-5xxx series radios available in low band? If so mobile repeat of low band analog to 700 P25 would work for them.The NX-5xxx series radios when run in a multi-RF stack setup will do mobile repeat internally without any additional equipment. Only time it wouldn't work for them would be trying to repeat a 700/800 channel, but their portables can talk on those systems without a VRS in most cases.
Maybe I'm missing something, though.
Yes, the APX-8000 portable should be able to talk directly on everything except low band as well.
This would be a possible option for them. Although I would go with low band, UHF (or a VHF/UHF dual band if available), 7/800 being that CHP has infrastructure in place on those bands.Yes, NX-5600H is the 110w low band deck. With a multiple RF deck setup, it will currently handle up to two more RF decks, so adding VHF high and a 7/800 deck would do the trick. An interconnecting cable between the DB-25's on the back of the RF decks will let it do a mobile repeat function.
It's my understanding that CHP wants in car VHF/UHF/700/800 interoperability with other departments as well as a separate in car system for CHP low band with a full duplex repeater system for the portables to connect to the CHP low band system, and possibly the interop system. The point being that I believe they want to maintain connection with the CHP system while also having a interoperability connection at the same time.
EF Johnson version (same radio, different software) will do 4 RF decks.
I have seen and got to play with a 3 deck setup. VERY NICE...drool.
Have you played with it?
It's quite underwhelming. The entire radio setup is strictly devoted to internal repeat, you cannot use the front microphone or panel, and to exit requires a reboot.
For it to be of any value, the internal repeat needs to be reengineered.
The VRS system can change channels based on the NAC it receives as well, even different RF bands.
