CI-V interface?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I don't know if anyone is looking for one of these; but I just came across this and thought I might throw it out there if anyone needed it...
Mike
majoco
Stirrer
New Zealand
Many years ago, about 2002, I bought a Yaesu VX-2, a tiny 2m handheld. I found a neat programme called "VX-2 Commander" by Jim Mitchell which required an interface from a computer Com port to a four-conductor jack into the radio. A bit of hunting and I found a constructional article on how to build one and it worked very well - the programme and the interface. A couple of years ago I found an Icom R7000 on our local web auction and again found a programme to talk to it - also called "Commander" but author unknown. A quick bit of soldering fitted a 2 conductor plug for the R7000 and would you beleive - the same interface for the VX-2 works for the R7000! ...and
-yes, it does work through a USB to Comport adapter! Photos and the original pdf attached.
  • Interface.pdf
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Martin, I suspect this is the program you used?
Mike
EricCottrell
Boston, Ma
Hello,
I looked up the schematic of the Icom CT-17 (it is in the manual). It is just a MAX232 with a power supply. The TTL TX and RX pins are connected together and go through a simple low-pass filter to the tip connection of the four mono 3.5mm jacks.
73 Eric
krokus
Southeastern Michigan
Hello,
73 Eric
(old post but just came across it and remembered I had the CT-17 CV-I)
Running Icom IC-R7000 with added Voice Synthesizer board (picked up decades ago from a local Surplus Store and fixed it).
Those appear to be 3.5mm TRS jacks, with the tips isolated. (Unless the leads are laid out differently than I am used to.)
