Has anyone found a proper lighter plug for the TRX-2? I would love to replace the 996XT in my truck with my new TRX-2, but for now I do not want to tear apart the dash to rewire the power cable.
Would I be safe using something as simple as this:Why not just put a lighter plug on the end of the DC cable?
Only if the device you're powering is actually rated to cope with direct connect to in vehicle electric power.Would I be safe using something as simple as this:
https://www.radioshack.com/products/radioshack-vehicle-power-adapter-plug
If I am using the 12v power cable that came with the unit, connected to this plug, how would that be harmful?Only if the device you're powering is actually rated to cope with direct connect to in vehicle electric power.
Or alternatively if you never run the engine while the device is connected.
When the engine is running current is pulsing through the ignition coil. You can get very short high voltage spikes on the 12V power rails.If I am using the 12v power cable that came with the unit, connected to this plug, how would that be harmful?
Sent from my Pixel XL using Tapatalk
How would that be any different than connecting directly to the battery which the included cable is intended for?When the engine is running current is pulsing through the ignition coil. You can get very short high voltage spikes on the 12V power rails.
Thanks. No issues keeping the fuse in the supplied cable as well? Sorry, not well versed on power anymore.Just get the plug you referenced from RS, it is what I have been using for years since I first got my PSR-600 it has a fuse in the tip to prevent issues.
No, no issues.Thanks. No issues keeping the fuse in the supplied cable as well? Sorry, not well versed on power anymore.
LOL! That's one of the funniest posts I've read on a forum in quiet a while. Thanks for the chuckle!When the engine is running current is pulsing through the ignition coil. You can get very short high voltage spikes on the 12V power rails.
As noted already, you will not have a problem with the Radio shack one you posted. That will work perfect, and yes you can leave the inline fuse and that will be fine as well.Thanks. No issues keeping the fuse in the supplied cable as well? Sorry, not well versed on power anymore.
