Cimarron CPlus II won't start
N9JIG
Sheriff
Moderator
Far NW Valley
I have a pair of Cimarron CPlus II MDC decoders that have sat around for a while. I plug in the 5VDC power cord it starts it's start up procedure and starts counting down from 9 as normal. Sometimes it gets all the way to 2 before going back to display "C Plus". The output relay clicks a couple times as it does when powering up.
It runs thru this for quite some time. Occasionally it will actually make it thru and the unit will function, but when I unplugged it to relocate it it is stuck in the recurring start-up process.
Both of my units do the same thing.
I looked in the install manual and there is no mention of such issues.
Any ideas?
N9JIG
Sheriff
Moderator
Far NW Valley
Well, I think it is a power supply issue. I found a third power supply and it works fine with the units. I am guessing that it is the voltage regulator, with no load the voltage is fine...
