Cincinnati Area Fedcom Logs
jsoergel
Cincinnati/Dayton, OH
Week of 3/23/14. All monitored from Fairfield, OH except for the two TSA freqs. Locations and inputs included when noted.
165.2375 $167 - FBI? *See note below.
165.2875 $650 - BATFE Net 1 (166.5375 $650 in) "Radio check on Net 1, how do you copy?"
171.9875 $167 - FBI, Cincinnati FO *Usually only KQC390 with station ID and times. However, did hear a unit calling for a check on Ohio plates.
172.7125 $551 - CBP, Cincinnati IAP
172.9000 $001 - TSA Ch. 7 (169.3000 in), Dayton IAP
172.9000 $002 - TSA Ch. 5, Dayton IAP
173.1500 $167 - FBI, Cincinnati FO
*165.2375 only opens up for one second (no voice); does this several times over the course of each day. I did catch two units in Dayton earlier this week on the frequency, but the NAC was not logged on my recording and I can't confirm that it was the same.
ChrisP
Portland, OR
Thanks for posting your logs.
However, 165.2375 MHz has never been an FBI allocation. It has always been a nationwide allocation belonging to Customs & Border Protection (formerly US Customs).
I highly doubt that the FBI would be using that, especially with their NAC. May have been a false NAC, as sometimes pops up with my scanners, both UNiden & GRE.
- Chris
jsoergel
I agree with your false NAC theory. Had $000 show up with the freq today. $167 also showed up with 165.2875. Seems like the brief hits are what throws it off; I'll have to wait for voice to confirm for sure.
Forgot to add some info on the Cincinnati FO; they have an aircraft based at I69 (Clermont Co.). Tail is N731CL but they use JENA 52 with ATC. Unit ID is CINCINNATI 500.
ChrisP
Portland, OR
I've always wondered if the NAC value is sitting in a buffer somewhere in the scanner, and when it receives a P25 transmission, but doesn't get enough info for a new NAC, it just displays what was sitting in the buffer from a previous transmission. Who knows…
- Chris
ecps92
Taxachusetts
NET 1 would generally use $651 as an input...
All repeater use $650 as the output tho
See what you get next-time, might again be one of those Buffer issues
jsoergel
No, just a mistake on my part. I don't recall if I monitored the input NAC, but I did hear them say "Net 1" over the air.
jsoergel
A few more logs from the past few days:
166.3500 71.9 - USPS Cincinnati (162.2250 in)
171.6875 $167 - FBI? (encrypted)
172.2125 $167 - FBI? (encrypted, one user in the clear)
410.0750 CSQ - FAA wind shear alerts
ecps92
Taxachusetts
-k
Great Reports....
Which airport was 410.0750 at ?? Seems to be a common Freq for this.
Altho I have begun to see more on 413.1125 from the FAA
ecps92
Taxachusetts
Net 1 uses $651
Net 2 uses $652
etc
So you must be near a NET 4 and 5
Hey Bill, I recently heard Net 1 input using $654 and $655 on two different nights.
Different $'s call up the closest repeater that the agent feels would work best for his location.
Bob
jsoergel
More updates:
167.3375 $167 - FBI?
167.3875 $167 - FBI?
168.5250 CSQ - DVA Cincinnati Paging
171.6125 $167 - FBI? (just found this one today, not sure if the PL decoded correctly)
406.1375 103.5 - USPS Sharonville
408.2375 $293 - DVA Cincinnati VAMC PD (417.2375 in)
414.4625 192.8 - ??? (could have been an image)
407.7250 $482 - USPIS Cincinnati?
jsoergel
JENA 52 currently with DAY A/D 118.850 for surveillance work. Shortly after checking in, 172.1875 $167 became active with encrypted traffic. Appears to be a simplex channel.
jsoergel
Some interesting Customs activity in early May.
OMAHA 1 was working surveillance over Columbus and Dayton for several days on 168.8375 $293 (AIR 1). Appears based at KTZR. During one day, heard Dayton attempting contact on 165.2375 $301: "OMAHA, OMAHA, this is SECTOR ALPHA 4712, DNET 3, Dayton." Eventually reached them on AIR 1.
Later that same day, CHARLIE 100 passed an Amber Alert on 165.2375 $301. The more interesting one was even later in the evening when I heard units working the DHL arrivals at CVG on the same freq - I've never heard them on it before and haven't logged them on it since then, either.
172.1875 $167 was active today, possibly in relation to more surveillance work from JENA 52 near Dayton. Heard the following transmission: "CI390 to unit calling Dayton, you're in the clear." No traffic after that.
jsoergel
Posting a full updated list:
165.2375 $301 - CBP DNet 3, "Dayton" (166.5875 $325 in), also heard in use once by CBP units at CVG
165.2875 $650 - BATFE Net 1 (166.5375 $651 in)
167.3375 $167 - FBI unknown - might be a simplex freq used in Covington
167.3875 $167 - FBI unknown - might be a simplex freq used in Cincinnati
168.8375 $293 - CBP Air 1
171.9875 $167 - FBI Cincinnati FO (KQC390)
172.1875 $167 - FBI unknown - might be a simplex freq used in Dayton
172.2125 $167 - FBI unknown
172.7125 $551 - CBP Covington, "Cincinnati IAP"
173.1500 $167 - FBI Cincinnati FO "A2" (162.7625 in)
407.0000 103.5 - FPS Dayton (416.0000 in)
418.0000 D516 - USPS Dayton (409.2750 in)
N1BHH
Jackson Square, East Weymouth, MA.
Something you may want to consider is the reaction time of the scanner. That reaction being, detecting the signal first, decoding into PL, DPL or NAC and then opening the squelch will take a few milliseconds. And between the three a PL is the quickest to decode, then DPL and then a NAC.
Ranger0034
Clearwater, FL
I agree about what Chris Parris stated earlier, about the NAC's sitting in a buffer, I too have received false NAC's on my HP-1 when just a blip of a fed freq pops up.
