city of dearborn mi.
rollin97sdime
dearborn michigan
so are my scanning days over for dearborn? is there something im not doing right or did they go encrypted. iam not sure help if you can. i have a whistler 1065.
GeneseeCoMI
Mount Morris, Michigan
Ronaldski
MI DB Admin
Bay City MI
Dearborn is in Wayne county, which is a simulcast-multiple towers county and whistlers do lousy in those situations. If you feel it is properly programmed, try taking off the antenna, use a paperclip or stubby antenna as you don't want to get all the towers which is causing too much signal. All you need is one to get the entire county.
Tower locations - https://www.radioreference.com/apps/db/?fccCallsign=WQVF811
Simulcast wiki-
https://wiki.radioreference.com/index.php/Simulcast_digital_distortion
See also - http://forums.radioreference.com/mi...um/359176-midland-monitoring.html#post2820409
and https://forums.radioreference.com/michigan-radio-discussion-forum/356989-phase-2-a.html#post2799619
Check
My reception FAQ's
RayAir
If simulcast is an issue for your scanner you can "try" monitoring the Northville site to see if Dearborn traffic is on it. It's C4FM, not CQPSK (simulcast).
Northville Site Control Ch- 853.9625
If you can run Unitrunker on the control channel that would really help to see if talk groups of interest are passed on that site.
As Ronaldski said, scanners are absolutely horrid when it comes to monitoring simulcast systems. Some to the point of being useless.
Good luck.
goaheadover
Banned
Good luck.
Dearborn is no longer using 158 on analog? or they are simulcasting? both systems?
Thunderbolt
Global Database Administrator
Ann Arbor, Michigan
No. They have switched over the MPSCS as their primary radio system. I haven't heard any radio traffic on the old 158.850 MHz frequency in a few weeks.
73's
Ron
rollin97sdime
dearborn michigan
love you guys
thanks for all the help from everbody's suggestions. i finally got my scanner rocking dearborn and dearborn heights. and its all thanks to you guys. love me some radio reference .
911Rewinder
Richmond, MICHIGAN
Does anyone have the actual talkgroup ID's for Dearborn City PD - I cannot located them in the MPSCS database. Thanks! Earl
rivardj
Michigan
https://www.radioreference.com/apps/db/?sid=100
Wayne County (82) Dearborn Talkgroups
DEC HEX Mode Alpha Tag Description Tag
22245 56e5 D 82DBPD911 Police: Dispatch [patched to 158.850 MHz] Law Dispatch
22246 56e6 D 82DBPDCAR Police: Car-to-Car Law Tac
22337 5741 D 343FD911 Fire: Dispatch [patched to 423.300 MHz] Fire Dispatch
22338 5742 D 343FG1 Fire: Fireground 1 [patched to 423.400 MHz] Fire-Tac
22339 5743 D 343FG2 Fire: Fireground 2 Fire-Tac
22708 58b4 DE 343PDB1 Police: Detective Bureau Law Tac
Wayne County (82) Dearborn Heights Talkgroups
22084 5644 D 82DHFD1 Fire: Dispatch Fire Dispatch
22085 5645 D 82DHFD1 Fire: Fireground Fire-Tac
22086 5646 D 82DHPD1 Police: Dispatch Law Dispatch
12243 2fd3 DE 82DHISD1 Police: Investigative Services Division 1 Law Tac
12244 2fd4 DE 82DHISD2 Police: Investigative Services Division 2 Law Tac
911Rewinder
Richmond, MICHIGAN
Thank you very much - not sure how I missed that! Have a good evening! Earl
