City of San Diego Public Safety
Cokeswigga
California
Good morning,
Does anyone know if the City of San Diego Public Safety is an APCO-25 system?
I assumed that the the County is a digital because the database indicates as such, but the city it says it's analog.
When I try to scan in San Diego on my analog scanner, I get the same kind of garbling on the City as I do on the County.
Any insight would be greatly appreciated!
System Name: San Diego, City of (Public Safety)
County: San Diego
System Type: Motorola Type II Smartnet
System Voice: Analog
Sysid: 2b2e
Last Updated: Changed talkgroups
Hits: 8607
System Name: San Diego, County of (RCS - Public Safety)
County: 2 counties
System Type: Motorola Type II SmartZone
System Voice: Analog and APCO-25 Common Air Interface
Sysid: 470f
CT: 105.88
Uniden DSP: 0333 1985 3542
Last Updated: Added a set of talkgroups
Hits: 29252
brandon
SoCal
San Diego City is all analog. It's a splinter system can be tracked by all trunk trackers except the PRO-92 (unless you have an earlier version). I heard a rumor they would go digital but lets hope that isn't for years to come :)
Cokeswigga
California
I've got a Pro-97, and I downloaded all the freq & talk groups into win 97 from this site,
so I am little confused as why I am hearning nothing but static from the San Diego Public Safety.
I live in Riverside County, but I am going to be back in San Diego on Monday, so I will take my programming cable and software and see if I can figure out whats going on.
I also have the same issue with the County of San Diego, but they show digital, which is why i was not surprised to not get anything useful.
WayneH
Forums Veteran
Super Moderator
Your master site
Cokeswigga, did you check this? If it isn't set for Splinter you aren't going to get great audio because splinter offsets the freqs by -12.5kHz.
I forget the keystroke but it Func-2 or something from the prog-trunk mode. You don't want it to say "Normal."
The RCS is still trackable with the 97, there's quite a lot of analog traffic so you'll just have to lock out anything above talkgroup 32768.
-Wayne
Cokeswigga
California
Thanks...
so all I have to do is click the splinter bottom on win 97, and I'm good to go?
How would I know by looking at the database, that this is a splinter system?
Do I need to set anything on the MOT Custom trunking Table
or the fleet map?
brandon
SoCal
Yup. Program as a splinter and you are good to go. No other customizations are needed for it to work.
WayneH
Forums Veteran
Super Moderator
Your master site
By the frequencies. Splinter is for 850-866 only. All frequencies are -12.5 so there's nothing greater than three digits to the right of the decimal point.
856.0000
856.0250
856.0500
etc
etc
Anything around Mexico uses splinter freqs. All systems in San Diego and Imperial Counties are splinter.
-W
