jeffmulter
>> The system is a JPS ACU 1000.
The JPS unit is not a system, but rather the means they are using for interoperability between two systems, such as Palnet and Orangeburg's new system.
http://www.jps.com/index.asp?node=88
>> I was thinking a uniden can't be used period from what you wrote about the dynamic memory structure.
Dynamic memory is used on Uniden's newest scanners, design-wise ... such as the 246, 330, 396, 996, BCT15. It is not used in scanners with a "bank and channel" programming format.
With a scanner like the 296, you program a control channel in a bank, and then designate whether its AM, FM, MOT, EDACS or LTR. The format enables you to do that to 20 channel slots, if you wish.
With a scanner using Dynamic Memory, the control channel is programmed in a separate module from the voice channels, so the "trick" doesn't work.
As mentioned previously, this system might be a flavor of LTR we cannot monitor ... except in conventional mode, such as Passport or MultiNet.
http://wiki.radioreference.com/index.php/LTR_Passport
