CL&P frequencies
scanner404
CT
I see that there hasn't been a thread about CL&P since 2007 and I wanted to get an update on any frequencies that CL&P is using now a days. Preferably in the Hartford county area. Is it even possible to listen to them since they are using MPT-1327 trunking? Are there any other frequencies they use and/or do they have a frequency to communicate with local police depts. If not, I think they really should have a communications frequency looking back at the October snow storm. Just curious; It would be great to know the status of them if and when my power does go off.
CT
Cl&p
This list is NOT official, however I heard traffic on many of these during the storm and other outages.
I forget where I originally obtained it. Sorry if the formatting is off.
37.4600MHz 37.46 162.2Hz
37.4800MHz 37.48 162.2Hz
37.6000MHz 37.60 162.2Hz
37.7400MHz 37.74 162.2Hz
37.76-Cheshire 37.76 162.2Hz
37.7800MHz 37.78 162.2Hz
37.8000MHz 37.80 162.2Hz
44.1400MHz 44.14 162.2Hz
44.3400MHz 44.34 162.2Hz
44.3700MHz 44.37 162.2Hz
44.7400MHz 44.74 167.9Hz
44.7600MHz 44.76 162.2Hz
47.8000MHz 47.80 162.2Hz
47.84-Tolland 47.84 162.2Hz
47.8600MHz 47.86 162.2Hz
47.9000MHz 47.90 162.2Hz
47.9800MHz 47.98 162.2Hz
48.0400MHz 48.04 162.2Hz
48.2000MHz 48.20 162.2Hz
48.34-Berlin 48.34 162.2Hz
48.3800MHz 48.38 162.2Hz
Torrington 48.40 162.2Hz
48.5200MHz 48.52 162.2Hz
War Room Middletown 48.16 162.2Hz
217.075 217.075 None
217.2 217.2 None
217.325 217.325 None
Mtnrider
Greene County New Yawk
A quick look shows them with some repeaters on UHF as well as Low band.....some mobile only UHF most likely for mobile repeaters.....
scanner404
CT
wow, that's a lot of frequencies. Does anyone know or have/has heard which ones CL&P uses most often or can be most heard during utility work, let's say at a downed telephone pole call in Simsbury?- (no reference intended to today's accident).
scanner404
CT
This morning I heard CL&P on the 48.34 Berlin channel, dispatching a crew for a call in Simsbury. Anyone else hear these frequencies being used?
cg
Connecticut
CL&P uses a bunch of different systems for different functions. Generally, they are as follows
Low band is for voice communications
Hi band for paging
217-220 for MPT-1327 system, mostly Western Mass Electric repairs & meter readers.
UHF for remote switching
900 MHz for remote switching
chris
keys
Connecticut
CL and P
Cheshire Area work center line trucks 37.76 meter and service 37.48 and 37.46 I am certain on 37.76. They also ID as Western Dispatch
Simsbury 48.34
Hartford underground 47.90 and overhead 48.20
Waterbury 37.80
I am in Bristol and know my circut numbers and their jargon pretty well so when they are doing switching I have a good idea what is happening and most switching and recloser opeartions are on radio. Not heard any voice other then low band.
scanner404
CT
Does CL&P use codes? I keep hearing them say the code "Signal 7" and was wondering if anyone knew what this meant.
MarkB513
Cheshire, CT.
It means the same thing as 10-4. In otherwords "roger" or "received" That's the only code I've ever heard them use, but it could come from a list of codes used a long time ago.
