cleaning 2180
WillB
Henry County
I was wondering what the best way to clean these radios is? Mine has been through a couple fires and smells of smoke really bad and I'd like to try and clean that smell off if possible.
ramal121
Lots and lots of watts
Calif Whine Country
Well the best way is to completely disassemble the radio and scrub the housing parts in a sink and rinse with hot water, then dry. If you're not willing to do that you can still spiff up a grungy radio.
First off, don't use an ammonia based cleaner on plastic. It can leave a haze when it drys.
For a quick clean up I use Simple Green and an old toothbrush. Lightly spritz the bristles and then work that into all the cracks and crannies of the radio. Wipe with a towel and then use compressed air (canned air works good) to blow out the last of the crud/cleaner and wipe again.
The idea is not to get the radio sopping wet. You want just enough cleaner on the bristles to dampen a spot and foam up as you scrub. Also letting the cleaner dry is counter productive, so doing section at a time is the best way.
Anybody else with suggestions?
llu727
New Jersey
As crude as it may sound, I have just slipped the front housing off, taken the lens out, and put it on the top shelf of the dishwasher. Seems to work well unless there is a lot of oily gunk on it.
Just dont use the "sanitize" setting!
