CLEMARS dos any one use them
ssd
NEVADA
dos any one use the clemars ch in the sac area.
868.51250 868.51250 WPAT870 M 156.7 PL CLEMARS 08 FM
868.51250 823.51250 WPAT870 BMRF 156.7 PL CLEMARS 09 FM
866.20000 866.20000 WPAT870 M 156.7 PL CLEMARS 20 Northern CA Use Only FM
866.20000 821.20000 WPNY310 BMRF 156.7 PL CLEMARS 21 Northern CA Use Only
or the i call
866.01250 ICALL FM
866.51250 ITAC1 FM
867.01250 ITAC2 FM
867.51250 ITAC3 FM
868.01250 ITAC4
and theDepartment of Parks & Recreation
what Frequency to use?
thanks vince
gmclam
Fair Oaks, CA
I hear traffic on the VHF CLEMARS frequencies all the time. I have the 800 MHz frequencies programmed, and have not heard traffic so far.
Parks & Rec, it depends on the specific park/etc. What area of northern Calif are you in and/or what specific park or parks are you interested in?
gmclam
Fair Oaks, CA
ssd said:
I am in Sac county, very close to the Folsom State Recreation Area. I get them (and Prarie City OHV) on 858.4875 DC 115. There is a list of P&R (800 MHz) frequencies in the database, each with a "color" name. I have them programmed and receive stuff from outside the area (for the frequencies which are not also used as part of the Sacramento, Roseville or Davis TRS).
Sac916
Several Sacramento and State Departments/Agencies use CLEMARS and I-Call freqs. Unless it is an Air-to-Ground operation you must be within a couple miles to hear the transmissions. Recently they have been used at the Calif Cap airshow and a couple training exercises.
They are very rarely used for patrol and dispatch communications.
or the i call
866.01250 ICALL FM
866.51250 ITAC1 FM
867.01250 ITAC2 FM
867.51250 ITAC3 FM
868.01250 ITAC4
thanks vince
RolnCode3
Sacramento/Bay Area, CA
I tried once to raise a CHP fixed-wing aircraft on the CLEMARS 800 frequencies. They were on a shots-fired call with us, but we didn't have any communication established. I specifically told my dispatcher to relay to CHP to use these frequencies, but communications broke down between the dispatcher (or more likely between me and my dispatcher).
The State Parks frequencies can be quite active, but I don't know all of their uses. The Folsom one that George pointed out is by far the #1 in the Sac area.
Other than that, I've never heard any traffic on anything other than the VHF CLEMARS.
zz0468
Banned
It's occasionally used here in Southern California, but there are a number of issues with it that prevent it from being used more. Riverside Sheriff, for example, has an extensive CLEMARS network that provides county wide coverage. But their deputies frequently aren't allowed to change channels in their radios without watch commander approval. The other issue is, in radios that have 250 modes, the users frequently can't find it, or don't even know they have it.
scannerboy02
ssd said:
Sac City Parks is on the PRKSAF (58448) talk group on the SRRCS. They also come up on the PD channels IDing as "park safety"
benca
Orangevale, ca
Clemars 20
Roseville PD motor units have used clemars 20 in simplex mode for coordination, and I'm sure that their dispatch has the volume up keeping an ear open while they were using it for their activity.
I'm sure more agencies use it but the low power simplex mode you need to be a few blocks away to pick them up.
