CLEMIS System Oakland County Michigan
davesscanner
I just replaced a very old scanner with the BC996T. Can anyone tell me the correct inputs for programming the CLEMIS system for Oakland County MI? Newby to digital and trunking.
smithken
Michigan
If this is the system I think it is then there is no way to scan it. Oakland County is migrating to a new system that is proprietary and not licensed to the scanner manufactures so there is no scanner made that can scan it. The last I heard there are no plans to make a scanner that can scan the new Oakland County system.
seamusg
Grand Blanc, MI
Although you won't be able to monitor CLEMIS, you can monitor MPSCS.
The Database here has all the information (inputs) you need to program your scanner. MPSCS is here: http://www.radioreference.com/apps/db/?sid=100
davesscanner
Thanks, All of Oakland County is migrating to CLEMIS. There are a few cities already using it.
