Cleveland Air Show 2017
Vark111
This years Air Show is here. Does anybody have any info on arrival schedules, practice schedules, or frequencies.
I went to the Selfridge Air Show a couple of weeks ago, and the Thunderbirds were using the following frequencies that weekend. 141.175, 149.65, and 235.25.
budevans
Cleveland, Ohio
Here's a link to what's been posted on the RR Air Show page.
https://www.radioreference.com/apps/db/?aid=7836
Not T Birds but you might want to check these out.
AF WQZW469
City of Cleveland, Ohio
Control Point 1 - 1501 N. Marginal Rd, Cleveland OH 216-390-8410
(link)
08/21/2017 License Issued
Special Temporary Authority expires 09/04/2017
1 - Burke Lakefront Airport; 1501 North Marginal Rd., Cleveland (CUYAHOGA) OH [Structure: Pole] (map)
[Antenna 1 - HTT: 5.7m, Polarization: Vertical, Beamwidth: 360.0°, Gain: -2.1dBi, Azimuth: 0.0°]
[Antenna 2 - HTT: 5.7m, Polarization: Vertical, Beamwidth: 360.0°, Gain: -2.1dBi, Azimuth: 0.0°]
118.35 FAC Ant: 1 5p 6K00A3E
128.475 FAC Ant: 2 5p 6K00A3E
Vark111
Thanks for the link Budvans. I have entered them all in my scanner. One question though, it lists airboss as 123.1000 or 123.3000. I have never seen those in use at Burke. Maybe they are generic airboss freqs, or maybe they were from another location. The only two freqs I have ever seen for Cleveland airboss were 126.4, or 135.875.
Burrhead- I didn't know they used temporary licenses. Do you think 118.25 and/or 128.475 will be used for the airboss? Could it be they use those for some of the civilian acts?
For those following the Thunderbirds- They used a different freq for the diamond on the Sunday from the one they used on Saturday.
scnrfrq
Erie, PA
I would say those are generic frequencies. I've never seen those used by the airboss anywhere. I have the Cleveland airboss freqs. from 2010 till last year (not in order): 126.4, 127.95, 128.475, 126.00, 360.60, 135.875, 138.875 (possibly).
128.475 was an airshow discrete channel last year.
budevans
Cleveland, Ohio
123.100 & 123.300 are Air Boss frequencies that have been used at other Air Shows. 126.400 & 135.875 are typically used in Cleveland.
Regarding the Temporary freqs, They are usually used by Acts, feeds to PA systems, etc.. Military acts like the Blue Angels and Thunderbirds have a group of frequencies that are essentially their own dedicated frequencies.
128.475 has been used for a number of years. 118.25 is new this year. If I remember correctly it replaces 127.95 which was used last year.
Vark111
I went to Air show arrival/practice today. The Thunderbird diamond used 139.8, and the Thunderbird solos used 235.25. I also heard some Thunderbird ground personnel talking to the Thunderbird lead on 360.6.
OHIOSCAN
Lorain Cnty, OH
todays log
TBIRDS Inbound 285.625 KZOB>371.950 KZOB>346.325 CLE DEP>354.025 CLE APP>339.800 KBKL TWR
139.800 THUNDERBIRDS Show Survey
141.175 THUNDERBIRDS A/A
346.325>339.800 EMPIRE 11
Vark111
You can add 149.6500 TBirds and Hopkins Mil Air 2: 273.4500 (Take off and Landing).
I was down low along N. Marginal. I think I might have been too low to hear the other two freqs. I will add them to my scanner. Thanks.
Also thanks to Burrhead for mentioning that they obtain the two temp freqs for the airshow, and what they are. What usually happens to me is I find the oddball aviation band freqs they are using late in the day on Monday. When it is almost too late to listen to them. This year, I will be on it right away.
OHIOSCAN
Lorain Cnty, OH
Logged today
BKL Airboss
118.350 AIRBOSS
128.475 AIRBOSS
135.875 discrete
TBIRD 7 354.025 CLE DEP>298.950 KZOB
Callsigns
CORSAIR flt
RHINO
THUNDERBIRD 7
Vark111
I went to practice again today. The Thunderbirds used the same frequencies today. 139.000 for the Diamond, and 235.35 for the solos. The Airboss used 135.875 to run the show, and 118.35 to work the LifeFlights in and out. 128.475 was used a lot as a discrete frequency for civilian acts and the Navy Heritage flight.
scnrfrq
Erie, PA
Was that 139.800 for the Diamond?
Vark111
Yes, sorry. The diamond used 139.800 on Friday.
I couldn't go to the airshow Saturday, and I won't be able to go today either. I will be there Monday though.
budevans
Cleveland, Ohio
Here's two TBird photo's from Fridays practice. It was over cast and hazy, but I got a few good shots.
budevans
Cleveland, Ohio
Here are two freq's not listed in the above posts.
Air Show Ground OPs: 451.6250
Burke Field: 123.1500 (Also used by the Golden Knights).
If you have a digital scanner, you can also monitor Burke Lakefront Airport Talk Groups on the GCRCN (Cleveland) P25 system.
TG 56080 Burke Operations
TG 56081 Burke Airfield Maintenance
TG 56082 Burke Fire/Rescue Operations
TG 56083 Burke Operations 2
