Clipped audio
kyparamedic
Central KY
We operate on an EDACS system and I've noticed that on some of the mobiles, the beginning part of the transmission is cut off. At first I thought it was operator error but if someone has a portable on, you can hear the beginning part that the mobile doesn't pick up. They're not scanning or anything. Is there a sleep mode or something?
mitaux8030
Silent Key
Home
Could it be late entry due to queing on a different site?
I've noticed that my portables (MRKs and LPE) both suffer a problem where it will miss an entire transmission (and proved it's not due to queing or fade) - no late entry, just an entire transmission missed. I suspect it's just the nature of the beast at times with all the software routines & interrupts running in the background of these 1st generation software controlled radios.
Perhaps ensure the mobiles have the latest firmware installed... thats about all you can do.
WCRadioGuy
Salisbury, MD
What type of mobiles are they and how long have they been in service? This does and doesn't sound like the same problem I had some time back. If you key the mobile for about 30 seconds with a continuous test count, does the audio drop and then come back? Does this happen on all the mobiles?
ElroyJetson
Check your system channel list with great care. If you blow one channel's data, the radio will eventually
be sent to the wrong channel to listen to a transmission that isn't there. This problem is more common
than you might realize.
Locally, some PD radios were in service for YEARS with incorrect trunked frequency data in them. Which
was the prime cause of the not-infrequent complaints about missed calls. It turned out that every such
radio had been programmed from one specific computer that had had one digit changed in the relevant
trunked frequency list.
Elroy
kyparamedic
Central KY
Elroy, that makes sense. It only seems to happen on the mobile radios, and they may have been programmed by a different computer with different info. They are all about to be reprogrammed because a new site is being added to the system so it should be a good time to check everything.
Thanks.
