900mhz
and decimal 20 equals 14 hex thats why I want to confirm whether it is hex or decimal
I verified this as correct. I reprogrammed both of my G4 devices utilizing " E " and got an immediate control channel lock on Troop I Bethany.
W1KNE
Owner ScanNewEngland
New England
It's RFSS 3 Decimal 14. The DB has been updated. Troop B will likely switch to RFSS 3, Decimal 12 shortly.
900mhz
Thanks, Mike.
Apparently, Uniden units display site ID data in decimal, while Unication devices require Hex assignments.
cg
Connecticut
The West and East Zones on the radio system are unrelated to the Western, Central, and Eastern Districts of the CSP.
I would think that Stamford may go to 3.2 at some point but just a guess.
900mhz
I have noticed that with all the flurry of changes in the Western part of the state, and associated database changes, the site neighbor data, when you dwell on each troop simulcast site, has not been updated...
W1KNE
New England
That information hasn't been provided to me, otherwise I would add it in. My source has only given the Site ID/RFSS data on these changes.
900mhz
When the site ID changes, i.e Troop I Simulcast was 29, is now 14, that data should change concurrently under neighbor sites.
Troop A was site 22, is now 11. Naugatuck was site 32, is now 21. Troop G was site 21, now it is 13. These are examples.
APX7500X2
NY/CT
Don't worry mike I don't even know what "dwelling on a simulcast site" is or how to do it in the data base, so everything looks great to me LOL
W1KNE
New England
I see what you're saying, that's an easy enough fix. When I have some time I'll go through it. I may wait until B has finally moved, so everything is completed at once.
900mhz
What the neighbor site data indicates is what additional site simulcasts are carried a particular site. Generally, they are adjacent sites. For example, if you scan just the Troop H site, you will not only hear "H" traffic over the "H" simulcast, but traffic from Troop's B, C, F, I, K and the downtown Hartford Simulcast. Knowing this may help someone to monitor a particular troop simulcast they would not normally be able to receive directly.
