Probably not for another 15 years or so.
chris
chris
Just checking, and sorry if this was already covered earlier in this thread. Has there been mention of CSP special ops or ESU talkgroups?
Here are all of the reported talk groupsHas there been mention of CSP special ops or ESU talkgroups?
Connecticut Land Mobile Radio Network (CLMRN) Trunking System, Statewide, Connecticut
Connecticut Land Mobile Radio Network (CLMRN) Trunking System Profilewww.radioreference.com
Connecticut (US) - The RadioReference Wiki
wiki.radioreference.com
ESU 1 is listed as TG 2023 on the unknown talkgroups wiki pageI've been checking periodically.
They were mainly in the clear on the old system and I had not specifically seen ESU or others listed to this point. It was just a curiosity, where I always had the ESU programmed after Sandy Hook.
Why do they have to be encrypted? Encryption is relatively new in its widespread use, so how did we get by all those years without it?I 100% understand why they have the ESU TG's encrypted and I'm actually happy they do. Two incidents I heard on there back in the day with very revealing tactical information on them that should have have been in the clear for the officers safety. Tactical close range channels like that I fully understand.
I know the technical ease and cost has plummeted, so it's a viable option to have in the radios and is no longer cost prohibitive, but is streaming that big of a deal? Surely they knew people could listen in before streaming? I'm just curious as to the actual need versus ability to encrypt.
- DHS grants - there's money tied to being able to have encryption and a push for P25
- Streaming - now you don't even need to spend money on a scanner to be able to hear pretty much any department
We should probably tread lightly on this topic as it's a bit controversial....I know the technical ease and cost has plummeted, so it's a viable option to have in the radios and is no longer cost prohibitive, but is streaming that big of a deal? Surely they knew people could listen in before streaming? I'm just curious as to the actual need versus ability to encrypt.
I still have a build from when my BCD325P2 was programmed with the old 800 MHZ system. I could send you the frequencies if you like.What’s odd about Danbury is i remember seeing a Troop A/I Simulcast repeater being listed in Danbury on the old State Police system. Too bad that system has been removed from the database or I’d see if I can find where it was listed. I believe it was on Wooster Mountain down by the airport. Hence my hope
Anybody with the ability to track new sites that live in the western part of the state want to take a ride to Danbury? I’m willing to bet there’s an unmapped site in the area. There are definite reception issues on CLMRN for us scanner operators that I’m sure CSP and DOT aren’t experiencing.
Not that I know of. But in other news, it seems my issue was scanner related. I upgraded to the SDS100 and now I get CSP no problems at work in Danbury. That is as long as I’m using a better antenna than stock lolI tried to PM you regarding your inquiry but it said I am not able to. Did you set it to not receive messages?
He only has 4 posts listed so most likely too new for PM's.I tried to PM you
I shaved down the end on my Watson WSMA-881so it will fit. Works like a champWhat Internet are you using for your Sds 100
