cloaning
captclint
Mountaintop, PA
anyone around the bucks county area that would be able to cloan scanners?
It would help if we knew what scanner(s) you wanted cloned. It may be easier for someone to send you a file that you can load into software and then download to your scanner. Of course, you could do it all by yourself by automatically downloading Bucks County from this site. Depending on your scanner, some software is free.
bobgolf
levittown pa
I have a pro 96. I already have bucks county. Just looking for some other stuff like maybe the philly airport and some misc things.Just thinking that someone who knows alot about scanners would have alot in thier programming.
captclint
Mountaintop, PA
Well, cloning would wipe anything you had in there out. You are much better off trying to add some of those things yo mentioned from our database. If you don't get anything on some, then reprogram something else. For instance, you have to be pretty close to the airport to get the tower and ground comm's but, you should get lots of planes coming in. Check out some of the Airline Company Channels. Conversations are fairly mundane most of the time, but you will certainly hear them coming and going.
