clock on xts 2500
tommul05
In the CPs I have added "clock" to the soft key menu, and I can not get the clock to display on the LCD any suggestions? Thanks.
rescue161
KE4FHH
Hubert, NC
Try the "General" tab under the "Radio Wide" screen. There is a time/date format. Under the time format, is yours disabled?
fineshot1
NJ USA (Republic of NJ)
I know on the XTS5000 you must first go into the menu and set the correct time before it will be on the display. Select clock from the menu and do an edit and see if that brings it up on the display......fineshot1
