May i ask your assistance? North Bergen, Hudson, New Jersey, but trying to include in the programming New York City?Trying to program some trunk groups in Northern New Jersey. Using Butel ARC500 Pro for my WS1040 Scanner.The PRO-95 is analog only and does not support 700 MHz frequencies. The WS1040 will decode P25 Phase 1. What is your city, county, and state and which agencies would you like to monitor? For the WS1040, you can use ARC500 or PSREdit500 software. I use Butel ARC500 Basic for my PRO-106, the older brother of the WS1040. Both use the same software.
I see that Oklahoma City is also Phase 2 which your scanner cannot monitor. I am going to add all of the conventional frequencies plus the few other trunk systems you can monitor to my original ARC500 file with the OKWIN trunked system.I jest Attach the zip file
Much of what you want to monitor is P25 Phase 2 which the WS1040 cannot decode. There is also a good amount of encryption. D in the Mode column means Phase 1 which your scanner can receive. T in the Mode column means Phase 2 which your scanner cannot receive. DE and TE are fully encrypted which no scanner can receive. De and Te are encrypted part of the time. You may also experience simulcast distortion which results in missed transmissions and garbled audio. If you attach your ARC500 .gr5 file, I will take a look at it to check for problems.May i ask your assistance? North Bergen, Hudson, New Jersey, but trying to include in the programming New York City?Trying to program some trunk groups in Northern New Jersey. Using Butel ARC500 Pro for my WS1040 Scanner.
I attached it above already zipped and ready to be unzipped in red by arc500 if you renamed 1040 I also have a pro 95 and a pro 106 can either of them receive phase 2 if not can you recommend a cheap uniden or radio shack scanner that can pick up everything on the cheap side?Much of what you want to monitor is P25 Phase 2 which the WS1040 cannot decode. There is also a good amount of encryption. D in the Mode column means Phase 1 which your scanner can receive. T in the Mode column means Phase 2 which your scanner cannot receive. DE and TE are fully encrypted which no scanner can receive. De and Te are encrypted part of the time. You may also experience simulcast distortion which results in missed transmissions and garbled audio. If you attach your ARC500 .gr5 file, I will take a look at it to check for problems.
The file you attached is a Win500 P500 file, not an ARC500 GR5 file. I have ARC500. Win500, and PSREdit500 software. I was asking wucherer to attach an ARC500 file.I attached it above already zipped and ready to be unzipped in red by arc500
I sent this post through my laptop, currently on my smartphone. Have previously attached a current file from my WS1040 scanner, but will have to go back to the laptop in forwarding a gr5 file. In advance offer my appreciate for your efforts. Thank you.Much of what you want to monitor is P25 Phase 2 which the WS1040 cannot decode. There is also a good amount of encryption. D in the Mode column means Phase 1 which your scanner can receive. T in the Mode column means Phase 2 which your scanner cannot receive. DE and TE are fully encrypted which no scanner can receive. De and Te are encrypted part of the time. You may also experience simulcast distortion which results in missed transmissions and garbled audio. If you attach your ARC500 .gr5 file, I will take a look at it to check for problems.
No! ARC500 is for the GRE PSR-500, PSR-600, the Radio Shack PRO-106, PRO-197, PRO-651, PRO-652, and the Whistler WS1040, WS1065.I jest found my pro-2055 can I use arc-500?
