Cloneing HT1250s
Luis_R
If you're using the cps you read the radio with the info you want or if you have a saved archive load it, connect the radio you want to clone, then write to it. Both radios have to be the same exact model w/ same features to clone.
If you are using the cloning cable then use attachment: Need to be same model w/ same features
Luis_R
both buttons are on the side. Button 1 is above the PTT button 2 is right below the PTT buton.
