Close Call and Beyond
russ130
Agawam, MA
Hello all, I have a question that I have not been able to find the answer to after searching for a lot longer than anyone should have to search. I have my BCT15X set up pretty much the way I want it. My question is how or can I take the close call hits and move them to a group with an alpha tag or can I give them an alpha tag if I can't transfer them to a group? Also I can't seem to find the scan group mode which I really have no use for until after the first question is answered. What I want to do ultimately is be able to just scan the one group late at night since it is local and anything going on is probably close to me. The older scanners you could just load up a bank with all the local stuff then just scan the bank. The group I created is in a system I created and it is the only group in the system at the moment. So if I had to I could just scan the system if group scanning is not possible. I created the systems and groups with free scan. Thanks for any help you might be able to provide me.
Voyager
Just use the Group copy function. Alternately, change the name of the Close Call system if you want to make a new System out of the hits.
wtp
Port Charlotte FL
i can't find the post
but in general it talked about how to have the radio save a hit to the "found" group automatically.
even as you sleep-save and store- and look at it later then just tag it the way you want.
Voyager
Close Call hits are saved to the Close Call system - Found Frequencies group. I don't think that can be changed. Other features can save things to other Systems, but not Close Call.
This is when using Close Call Auto-store.
