Close Call and DMR
pb_lonny
Tasmania
I have a couple of local radio users who have switched to what I believe is DMR (this is based on the audio samples I provided.)
I can recall reading that Close Call does not work with DMR as the signal duty cycle is too short to trigger Close Call, yet I am getting multiple Close Call hits on one frequency in particular which makes me think it might not be DMR. Is this correct?
racingfan360
Close Call will not detect on a DMR Simplex or Uplink channel. It will detect the Downlink (Repeater) channel (in fact all Uniden scanners will close call on the Repeater signal - it's not just limited to the new DMR-capable scanners).
If you record and upload an audio sample of the raw signal, I can likely help you understand what type of transmission it is. Alternatively, this site might help: http://www.sigidwiki.com/wiki/Digital_Mobile_Radio_(DMR).
toastycookies
the far east
Why won't close call detect a "DMR Simplex or Uplink channel"
This makes no sense.
racingfan360
For close call to work, it needs to a relatively strong signal (I think it needs about +15dB higher than the local noise floor) but it also needs the signal to be present for a sufficiently long period of time for the scanner to latch onto it. I think the DMR single slot TDMA frame is only around 30ms long, and that's too short for Close Call to work. The repeater signal uses two slots interleaved, and that is sufficient for Close Call to work.
gary123
Interesting reading UPMan.
Without going into detail. this is my take on the feature.
Is it possible to modify or configure CC to work on DMR - yes
Is it practical to make these modifications - No
Would such modifications be reliable - No (will constantly false on impulse types of noise)
bottom line is Uniden is correct in not trying to support CC on DMR or TDMA types of signals
N9JIG
Sheriff
Moderator
Far NW Valley
Not quite. CC works fine on DMR repeaters, it just the mobile or simplex TDMA transmissions it cannot detect.
I often get DMR/TDMA repeater hits just fine on my Uniden DMR scanners.
gary123
Good point N9JIG. I was assuming that the CC issue was in picking up simplex or single time slot users. The repeater sends both time slots even if only one is active. This is why the scanner can get a CC hit.
Ubbe
Stockholm, Sweden
I can recommend Aceco SC1 plus for detecting digital transmissions like tetra and DMR mobiles. It also detects mobile phones and works excellent with all kinds of signals. The only negative is that it lacks a memory function.
/Ubbe
gary123
One nice future use for CC would be a dual sensitivity setting one for in city/town and the other for in the country. Monitoring via a SDR lets me see the relative signal strengths and when out of town I use a preamp to pick up repeaters (works/roards etc) for the various small towns in the ares. If CC was a bit more sensitive in these low noise environments it would add a lot to the scanners performance.
ynot58
Dmr nxdn
Trx1 on spectrum sweeper detects all inputs dmr and nxdn regardless of duty cycles on simplex trunked or conventional as it simply picks up the frequency during sweep. The dmr input for example may not trigger close call but spectrum sweeper stops on the input frequencies because the person is still keyed up talking after duty cycle And is monitoring it thus showing the frequency and relevant information and has never failed yet and works at a decent distance
vizzini
Does SDS100 have the ability to do "sweeps"? I'm not sure if Analyze or Discovery does something like TRX-1's sweep. If so, then SDS should also be able to pick up input DMR transmissions.
Ubbe
Stockholm, Sweden
Whistlers Spectrum Sweep are probably patented. Uniden can use its slow search function to achive the same thing but it could take ages to hit a frequency just when someone transmits on it.
/Ubbe
AA6IO
Cerritos, CA (LA County)
I have one of my Zumspots parked on 433.1000 Mhz for DMR on time slot 2. Have several static talk groups going through Brandmeister. My SDS-100 using close call picks up all these transmissions flawlessly, at least within the confines of my house and nearby outside. Audio quality of DMR on SDS-100 from Zumspot is excellent. Even shows the Talk Group and individual DMR (CCS7) IDs.
Ubbe
Stockholm, Sweden
Your DMR hotspot transmits a carrier on both timeslots, a continous wave, but only sends information in the timeslot you have configured to use.
/Ubbe
