I’ll happily do so, but I don’t know for sure whether or not I have had recording turned on when I’ve had digital close calls. I’ll poke around at it soon, but in the meantime is there any known way to search for close call wav files in windows, where I have all my recordings dumped to a directory on my hard drive? I know some meta info is provided like the system name. Would I be able to search for artist (or other field) of “Close Call” to find only those candidates out of the thousands of recorded wav files?
CloseCall.exe
this is very very simple program which can help you to find Close call files in your wav files archive.
After start this program you must write directory with uniden wav files.
like this D:\radio rec or d:\radio rec or c:\temp etc.
after this program shows you where saved log file
after this shows all close call files
shows total wav files in directory with sub directories
and that's all)))
in directory that you write in first step now you can find file "CloseCallFiles.txt"
which contains info like this:
d:\radio rec\4EC82BAF\test\2019-04-06_11-53-53.wav
d:\radio rec\4EC82BAF\test\2019-04-26_14-45-38.wav
d:\radio rec\4EC82BAF\test\2019-04-26_14-55-26.wav
d:\radio rec\4EC82BAF\test\2019-04-26_14-55-36.wav
d:\radio rec\test\2019-04-06_11-53-53.wav
d:\radio rec\test\2019-04-26_14-45-38.wav
d:\radio rec\test\2019-04-26_14-55-26.wav
d:\radio rec\test\2019-04-26_14-55-36.wav
this is your close call files.
Tested on windows 10. writed on c#. Not completely tested. may not run at all PC.
Not realized directory check. If you write incorrect directory program may hangs.
