Close Call - Saving hits
mkrubsack
Fresno, CA
I have Close Call Do Not Disturb (CC-DND) active on my BCT15 and BCD996T. When using bcTool, the log saves the Close Call frequency hit.
My question is, is this same info saved in the scanner somewhere? If I have CC-DND active, but am not running any software, does the scanner save this info? I looked through all sorts of menus in the radio(s) but could not find the hits.
I tried CC-Autostore, but then I lost the ability to scan...the radio just went into Close Call search mode.
I want to scan, have Close Call active, and be able to later review the close call hits. Any help would be appreciated. Thanks!
Mark, K6MAK.
UPMan
In Memoriam
Uniden Representative
Arlington, TX
The scanner will temporarily save up to the last 10 (or number you set) hits. These hits go away when you cycle power. To permanently save the hit, press E during the hit and the scanner will save it in a "permanent" system.
