royalzapper
We have a Digital Scanner Team located in Hamilton County, Ohio
that meets weekly and have set up a Cloning program that is shared
weekly with our local Radio Shack Stores.
The Hamilton County, Ohio TRS System is programmed in the PRO-96
and the PRO-2096 using the Win 96 Software.
Hamilton County TRS (APCO-P25 9600 baud)
System Type: Project 25 Standard
System Voice: APCO-25 Common Air Interface Exclusive
When the Radio is functioning correctly (In the Open Mode),
the Radio always stops on all transmissions except those you
specifically locked out. The display shows MOT: ID # of talkgroups
that are not stored in the Radio’s ID list. If the transmission is
that of a stored talkgroup, Radio will display the Alpha Tag.
When the Radio is functioning correctly (In the Closed Mode),
the Radio only stops on the transmissions and displays its Alpha Tag
of talkgroups that have been stored in the Radio’s ID list. You will
not receive transmissions of talkgroups you have locked out.
Showing on Radio Display,
When in Scan Mode under the Bank # Open Mode (+) Closed Mode (-)
We are aware of this function changing from Alpha Tag Display
to ID # Display.
By default, your Radio displays the stored Alpha Tag when receiving a
talkgroup transmission. You can toggle the display to show the Alpha
Tag or the talkgroup ID # by pressing TEXT while the radio is stopped
on a talkgroup transmission.
We have found some PRO-96 and PRO-2096 units that have a problem!
Lets call this problem "Closed Mode MOT: bleed over".
Banks are in Closed Mode but function as if they are in Open Mode!
The Radio will show stored Alpha Tags and receive transmissions of
the stored talkgroups.
When the Bank is set up in the Closed Mode, the problem is receiving
transmissions of talkgoups that haven’t been programmed in the
Radio’s ID list. The Radio will display the MOT: ID #.
Also if you lockout this MOT: ID # that was displayed, the Radio will
lockout a different talkgroup that is stored in the Radio’s ID list,
and doesn’t enter or lockout the MOT: ID # that was shown on the
display.
You should never have MOT: ID # on the display and receive a
transmission of a talkgroup that is not stored in the Radio’s ID
list.
Would like to know if others are aware of … or having this problem!
Maybe this is only a local problem!
royalzapper
:arrow: add to this post on 7/22/2005
If you reply to this post
Please advise what type of Trunking System
is programmed in you Radio?
36 or 96 baud and give the name of the system.
Turn your Radio on & During Welcome screen display press the 3 button
What is your CPU, DSP application and DSP vocoder versions
Display will show
CPU: F1.3
DSP-App: F1.2
DSP-Voc: F1.0
We have seen this problem on CPU 1.2,1.3 & 1.4
royalzapper
to ID # Display.
display.
list.
royalzapper
Display will show
CPU: F1.3
DSP-App: F1.2
DSP-Voc: F1.0
royalzapper
