Clueless on DOS
Mattkuhar
New Haven County, CT
hi everyone, not sure im posting in the right spot (mods feel free to move this) i will be getting some HT1000's in the future as i hear they are very good portables. i hear the programming software for them is only available under DOS. can anybody enlighten me on how to use DOS lol. and will the software run under FreeDOS? im not very familiar with a command line but i am more than willing to learn how to do it.
Thanks Everyone
33kracing
grand island, ne
i think you have to get an old school computer that runs on windows dos...then u need a rib-box and rib-cable. then the rest is 1-2-3
Mattkuhar
i do have a very old laptop currently that i can install DOS onto (cpu runs at 233Mhz) whats your experience with the ribless cables under DOS? i have one for a kenwood now that runs under XP pretty good.
33kracing
grand island, ne
i dont think moto radios that old can program without a rib cable... only the newer ones can. and i suppodr the kenwood radios are the same
MTS2000des
5B2_BEE00 Czar
forget using USB anything with these old radios. Ribless cables are usually fine, provided you have a good stable DOS platform. The HT1000 RSS is out there, and the later versions (3.03 and higher) will actually run on CPU's as fast as 2GHz.
I use a Panasonic Toughbook CF-29mk 5 which has a 1.6GHz Pentium 4M, booted to MS-DOS 6.22, and run the HT1000 RSS off a small FAT16 partition. It works fine and I have never bricked a radio or had any issues, I use this with a genuine Motorola RLN4008E RIB and aftermarket RIB to radio cable.
Mattkuhar
Cool ribless sounds good, i think ill be installing DOS 6.22 as soon as i find a floppy drive for my computer (or can it install off a cdrom?) i did find HT1000 software but not sure which version yet so ill try it on the old machine first.
teufler
ST PETERS, MISSOURI
the rss software, for the ht1000 and others that require dos, no big deal. you just answer commands by selecting items from your number keys. actual dos, you don't have to know.. case of the software is smarter than the operator. some times I could run in windows with a shell to dos function, using powerdesk. The program has an open dos prompt than allowed rss software to run.
For your question, a old pc using windows 3.1 would be fine. I use a windows 3.1 laptop a old toshiba satellite monochrome laptop with upgraded ms dos. Since it's old platform windows 3.1 starts and I run the rss from it. Never had one problem. I also used a compaq presario cdtv old machine with windows 3.11. It ran fine also off the rss icon in windows that would launch a program into dos. Ribless cables on these old radios worked fine. You may check the com settings after installing the rss to ensure proper comm is selected and the file directory to save codeplugs.
RodStrong
West
I use a ribless cable for HT1000's and it works fine.
Good luck.
Mattkuhar
i wasnt aware that the RSS could be run under 3.11. do you have any experience with running it under a virtual machine? just found a tutorial to install without a floppy drive into a virtual machine but i dont know how the radios would like to run under that.
N4KVE
PALM BEACH, FLORIDA
Unless you are getting the HT1000's for free, I would suggest you pay an extra $10 per radio & purchase MTS2000's which can be programmed with a modern computer using CPS. So much easier to program, much better control of the 3 position toggle switch, and a top mounted display.
Mattkuhar
CPS means they program under windows right? if thats the case that would be so much better on my end :) im looking on ebay now for MTS2000's do they have them in a VHF flavor? so far i only see 800Mhz
N4KVE
PALM BEACH, FLORIDA
VHF, UHF, 800, & 900 mhz. And yes, Windows, but probably not Win8. Plenty of cheap Windows XP laptops floating around with real serial ports.
Mattkuhar
BLECK!! thats ok, i dont like windows 8 lol. i have an old XP Laptop with Serial im using now to mess around with my Kenwood TK-780, now just need the cash for some MTS2000's the cable, and the software (what should the software run me btw)
Mattkuhar
good to know, will go find and install it now then. thanks for recommending the upgrade to MTS2000's windows programming is so much simpler IMO
Otis413
Cass WVa
I used an old IBM X41 laptop with a dock that has a serial port, (KaWaMall ribless cable), the HDD is shot so I boot from a thumb drive to MS-DOS 6.22.
I like the thumb drive boot (USB Boot must be supported in the BIOS) because I can plug the TD into my desktop PC and add software and backup the codeplugs. This works great with my HT1000s and MaxTrac 300s, but wouldn't work with my MaraTrac, the laptop was to fast for that RSS and I had to set up an old 75mhz desktop for those...
jaspence
Michigan
DOS programming
You can boot and run the RSS from a floppy if you don't have USB boot capability. Depending on the size of the RSS, you may need two disks, one for boot and the other to run the program. The kawamall cables with the chip built into the connector work quite well for my older radios.
