CM200,,,,,,,,,no way to reprogramm them?? today.No CPS anywhere??
ve2rxy
Riviere-Bleue,Quebec
hello everyone,
i saw a gentleman that have a repeater made from 2 ,CM200 radios .But i found nothing to reprogramm them!
i have an OEM cable for the CDM1550,,i wonder if it could worked?
i am not an expert on motorola !
thanks guys
it is for a radio club here that dont have much $ and this small repeater could save them a lot of $ that they dont have
73
Gervais,VE2CKN
clbsquared
Isle of Wight County
Yes, the WARIS series programming cables will work on the CM series. Just make sure it’s an FTDI cable and not a Prolific. CDM, CM, M1225 radios use the same cable. Different CPS but the same cable.
lamarrsy
Rimouski, PQ, Canada
Hello Gervais, you don’t say if it is a VHF or a UHF setup.
If it is VHF, you will need CPS # 05.16 as this is the latest CPS allowing you to program wide FM.
Motorola has restricted all CPS to narrow-FM to comply with the 2013 FCC rule.
You also can’t use a regular Motorola RJ-45 cable to program them.
Check this page for good info about this Commercial Series radio : The Motorola CM200, CM300 and PM400 (and similar) Mobile Radio Index page
I have a UHF CM200 in my shack, and I do have the right programming cable, you could borrow it the next time you come in town.
Let me know via a private message and i’m sure we can can coordinate something.
