CM200
lorentedford
Olney, IL
Hi could some one post the bat board message on the correct pins I know they are 1 and 3 is this from the left of the RJ45 or the right side of the RJ45 and is there any Diagrams I need this to program the recieve on my 16 pin acc port on my repeater
lorentedford
Olney, IL
Hello I am trying to reprogram my CM200 to allow it to recieve out of the 16 pin Acc port on the back of the radio I have two radios alike both are programmed and tuned the same however the place where I had the radios programmed at did not leave the Acc port open for RX only for transmit side. I am using a DMK Eng URI that with cable from URI Cables From what I understood the pin out is the same from Maxtrac to GM300 all the way up to the CM200.. Any ideas on how to program this thing I did find some software online and do have a Multi plug adapter to serial.. However I keep geting an Com error.. Was wondering if I needed to adjust the settings on the speed that it talks to the radio not sure how old this stuff is..
lorentedford
Olney, IL
---- Solved ---
On pin 8 need to select Talk/group CSQ in settings the 16 pin accessory pin works great!!
