CM300 cable question
firefive76
Kansas
Ok, I understand that the cable to program the M1225 will not work alone on a CM300. I have seen some discussion that the M1225 cable will work if you buy the $65 Motorola flash/prog adapter. Anyone tell me if this is true?
Yes, it is true. It is also called a "dongle". I have one out on the bench and will get you a part number this afternoon if you need it.
firefive76
Kansas
Is it the FKN8096B? Just wanted to make sure this was correct. So you can use the regular RIB, connected to the FKN8096B and the 3080070N01 (M1225 program/test cable) and program the CM300. Will this also program the PM400? Thanks again!
firefive76
Kansas
It's all for a department, who will only buy from Motorola. Has to be Motorola original.
I should have asked first, are you using a ribless cable or a standard cable requiring a RIB?
