CM300 current draw
firefive76
Kansas
We have a vehicle that has a CM300 in it. The battery slowly dies in this vehicle if it is not driven regularly/very far. I did some troubleshooting on the add-on equipment and found that the CM300 is drawing .25 amps turned off. Turn it on and it jumps up to about .28 amps with no receive audio. Is there a reason that it is drawing just almost as much current when it is off as when it is on? I checked another CM300 and it was drawing .001 when turned off. Any suggestions?
firefive76
Kansas
Got it!
Just wanted to update this in case anyone stumbles upon it with the same issue. I talked to a radio tech and he asked if I had an external speaker, which I do. He said to look at the accessory connector and see if any pins were looped. Pulled the radio and sure enough, there was a loop. Cut the loop out and now no draw with power turned off!
