Cm300 Help!!!!
renze8173
Iowa
When Trying To Read Radio, Message Reads <error #2409 Unable To Read Feild Value>. Any Thoughts?
N1GTL
CT
Do you have the FKN8096B flash adapter in line?
renze8173
Iowa
I'm not sure what that is. Thinking that my software is older <R05.07> and the radios have been programmed by something newer. I also have an USB programming cable that works for some of the radios that I've programmed with this software. I hate to bring them to a Motorola Dealer to have them programed when I can do it myself. Don't know if Batlabs wpould have info?
N1GTL
CT
5.08 is the newest software. If you have a newer radio, the firmware will require the newer software. The flash adapter I mentioned is used with a RIB. I have only used real Motorola cables and RIBs with the CM and SP series radios so I can't answer your question about the USB cable.
