CM300 MDC problem
firefive76
Kansas
Have programmed a few CM300's. On a few of them, I have enabled the MDC PTT ID on a certain channel to encode and decode and have had no problem. I have one CM300 that I have set up just like the others and it will not decode or encode MDC. It DOES chirp when keyed up on that channel, so it is sending something, however, none of the other radios display anything. Also on this radio I noticed under the signalling that it has a "primary ID" and a "group ID." The radios that are working OK aren't showing the "group ID" at all on the signalling menu. Any ideas on what is different about this radio?
firefive76
Kansas
did you program the Same ID in one of the radios?
Sure did, finally hit me while I was trying to figure out what I was doing wrong. However, I have not figured out why one radio has the group ID and the others do not.
