CM300 pin out
bucklebd
Lucasville, Ohio
I am trying to set up a CM300 to activate our siren when our pager tones are set off. I know there is a way to configure the pin outs to activate a relay. Can anybody help with the configuration.
ramal121
Lots and lots of watts
Calif Whine Country
You will need to program one of the "programmable I/O" pins to activate on proper tones.
AHA! Caught you on something LOL. You can only use pin 4 as an alarm output to drive a relay (per the OP). Other I/Os are TTL compatible only.
Yes, connect pins 4 and 7. You'll need a relay with a 12 volt coil. Connect pins 4 and 7 to the coil. Observe the current limit in the manual of 150ma (.15 amps), you don't want a big honkin' relay, just one big enough that will support the load of your siren trigger. Easy project. I'd suggest getting the correct Motorola 16 pin connector to make it easy. There are a number of them for sale on e-Bay for cheap. You get the actual connector with a bunch of pre-crimped pins with about 6 inches of wire. Make for a really easy install.
