Cm300d code plugs
Bfriel
Port Alberni
Hello all my first post
I have a cm300d and a programming cable
And have tried a few versions of cps2.0
My question is when I try to read radio I get
#101005 code plug not supported
Is there a way to correlate a code plug to a software version
Model number is aamo1nh9c1a
Firmware r01.21.01.0000
Code plug 21.10.51
I am happy to pay for software I’m just a bit of a noob when it comes to these more modern radios
Local radio shop closed a couple months ago
So no local help
Thanks in advance for info
Brett
sfd745
Reverend Higgy
Southern Maine
No, you cannot create a codeplug from scratch. If you are not getting the radio to read under the latest version of CPS2, try CPS16, as the earliest CM300d radios did work with that.
jeepsandradios
East of the Mississippi
are you sure its a CM300d and not a CM300 ? The 300 used commercial programming software, not the mototrbo stuff. If it is a d model are you using latest CPS2 ?
