CM300D Keypad Tones
camsdad
What happened to the standard radio front keypad tones? Is there somewhere in the CPS that it or they need to be enabled?
Not caring much for Voice announcements.
Thanks for any help or direction.
camsdad
I found that option, But I just want the radio to produce a beep when I press volume up/down or channel.
Like the CM300 used to do before.
Floridarailfanning
East Tennessee
I was wrong about that option I mentioned above. If you have the Tones/Alerts menu option enabled you should be able to go in the radio's menu and turn it on.
On the radio: OK < Utilities < Radio Settings < Tones/Alerts < Keypad Tone
camsdad
I appriciate this endeavor but I have found no Keypad Tones option anywhere to be found in this CPS.
Floridarailfanning
East Tennessee
I think you misunderstood. This is not in CPS. The only way I have found to turn on the keypad tones is to actually power on the radio and enter the utilities menu.
I tried just now on an XPR5550e and it works fine. It used to be the same on the CM300d's that we had.
camsdad
Found It!
It is a front radio panel setting. Press Menu OK button thenP2 or P3 to Utilities Menu OK\Radio Settings\Menu OK\Tones Alerts\Menu OK\ scroll via P2 or P3 to what tone feature. Press the Arrow Back\Home to go back. See page 96 of the user Manuel.
What a POS engineering setup.
