I'm guessing you're referring to 163.050, CG112.
Communications there are likely to be P25, encrypted for the most part, and also for the most part simplex in nature. As mentioned in post #2 the other station/vessel/whatever it may be is just simply out of range. The same thing happens here on Cape Cod where primary operations are on CG127, 171.2375. That's just the way it is.
