Coax/Antenna Analyzer Recommendations
cpg178
Looking to purchase something so I can sweep coax and antennas, I see a Anritsu S330A Site Master Cable & Antenna Analyzer for sale on embay for about $600, it looks like it will do what I need... is this worth it or should I spend a bit of money on something newer? This is mainly for hobby use
rf_patriot200
Freeport, Illinois
Enritsu's are Very good from what our repeater owner says. He owns one himself, but I don't recall the model.
tweiss3
Is it time for Coffee?
Ohio
It also depends how high you need to go? Is 900MHz high enough, or do you want GHz coverage? I have a NanoVNA and a TinySA, but I did end up getting a RigExperts Stick XPro that does up to 1000MHz. For the quick check, its instantly faster than the NanoVNA, and the app is helpful for capturing data, but it was expensive. Beyond that, the NanoVNA will do anything you need hobbywise.
For the Anritsu S330A, it only does 700MHz to 3300MHz, so it won't do typical UHF/VHF/HF if that's what you intend to use it on.
cpg178
Thanks for this, there was limited info on the ebay listing. Looking for VHF/UHF no need for 7/800 or higher
Hobby use? NanoVNA will do what a lot of people need. I have a Nano VNA at home so I don't have to bring the work stuff to do quick tests.
Looking to have something to sweep my coax for my repeater, and some unused runs/antennas on the site that may be of use.
cpg178
That would be worth the extra cost for a good one, especially one with a good tracking generator so you can tune duplexers. One with a nice big display makes life easier.
Any recommendations, it looks like a lot of these are meant more for the cellular world.
I am a lineman for the county.
I've got an Agilent at work. N9342C. I think about 12 years ago it was $18K new. Probably find it a lot cheaper on the used market. It'll do up to 7GHz, which you probably don't need. You would want the tracking generator. Mine will sweep coax and analyze antennas. I don't use it very often anymore, but when I do, it's a nice unit to work with.
I've heard the FieldFox units are nice, but never used one myself.
I know there's a lot of cellular only stuff out there on the used market. I think just looking closely at what they are selling is important.
merlin
DN32su
My suggestion is the NANO VNA. I have the H4 model that includes a TDR which is perfect for analyzing coax and feeds.
It has more functions than the average hobyist would need, but capable of the engineering grade like the Anritsu.
Pretty good for less than $100.
freddaniel
Newport Beach, CA
Attached is the comparison chart for the older Anritsu antenna analyzers. These also sweep feedlines for total loss and do TDR sweeps for shorts, lumps and kinks. Some also come with Spectrum Analyzers built in. Like with a VNA, to calibrate you need a SIMPLE shorted connector and a reasonably flat 50 ohm load that covers 0 to 1 GHz. I also use a 10 dB attenuator that measures at 20 dB return loss for a calibration test.
Also look for a MT8212B analyzer. It has everything and lots are available on Ebay.
cpg178
Thanks everyone for the help! All this will get me pointed in the right direction!
Pittsboro IN
I got a nano VNA about a month ago and just started testing it. The cal load for my Site hawk shows as 34.9 dB return loss at 454.250 on the Bird, my Copper mountain R54 shows 32.3 dB and the nano 25.9 dB. This was done using 400-500 MHz. I am still learning the nano menu system, I did calibrate before taking the S11 reading so I'm wondering about the 6 dB difference.
The Bird reading was done with their blue cable, I had to use a female barrel adapter with the cable on the R54. I used the nano SMA cable with an adapter to the N load so that accounts for some difference. The SMA coax has 0.11 dB cable loss.
The cal kit with the nano is pretty poor for the short and open, the load is 40 dB on my R54 calibrated with a Siglent kit. These Smith charts show the short and load, the red arrows show the ideal reading on the horizontal line.
Ubbe
Stockholm, Sweden
When measuring antennas they are still active receiving everything in the air. A bad analyzer has no protection for that and could also very easily overload and give false results. The best analyzers use some kind of coded signal, a special modulation scheme, so that only the signal that comes back with that specific signature are analyzed and not a bunch of other transmitters in the frequency band you are analyzing.
I worked with a Site master, don't remember the model but it was something like $3,500, and that still had some issues if it was a transmitter antenna in the same frequency band too close on the roof. They can't handle too big signals, at least not in that price range.
/Ubbe
Pittsboro IN
I use an example of that in my ETA class. Even a good VNA has limits, the R54 is 23 dBm, the Site hawk is 22 dBm, even has ! next to the connector extra warning. One of our intrepid members saw this situation the day after he took my class and was kind enough to send a photo of the screen.
cavmedic
Pottstown Pa
Yes, it was a VHF paging transmitter about 30 feet away . There was 7 watts reflected power every time that transmitter went on the air and the site master gave me the middle finger. The only way I could properly test the antenna system was to unplug the inbound link antenna on the offending paging machine.
