How or what would be the best way to bring the coax into the shack ?
Little info on what I have to work around .....
Ok, our service line to the house is on a pole just out side the window about 50ft away or so, and the breaker box is also in the same room the shack is.......and at the present my coax cable is coming through a window that slides side to side, instead of up and down, and about 4-5ft up off the floor.....the wall under the window has 2 outlets n it and that's it......
I have 2 of those EFHW 8010 antennas up, one is out back and the coax at the present comes down through the yard and under the walk way, and on to the window on the side of the house, and the other one is out front of the house, and that coax runs up to the window of the shack....
Also, going to change out the way I have my ground system too, will have a short run to the ground rod..
Can't come through the basement.....
So, how would u all recommend bringing the coax into the shack ?
Would it be ok to run the ground wire through with the coax cables ?
