Try to get the Larsen NMO HF mount that uses their UD coax specification (LMR-200). The HF is their "High Frequency" mount that's backwards compatible to the normal NMO mount so it'll work with antennas designed for either the old or new spec. The UD coax is their RG-58 double shield "low loss" cable, that is actually LMR-200. The mounts are available in both normal and thick sizes so most normal installs can be done. Nearly all NMO antennas will work with them and the normal Larsen NMO accessories can be used.
