APSN556
My question to the gurus.
I have a discone antenna in my attic (HOA wont allow it outside, nor will wife) therefor weather and lightning are NOT an issue.
The single discone feeds 4 scanners, thanks to a Stridsberg MCA204M VHF/UHF Receiver Multicoupler.
Im not sure how I will feed the coax however from the attic to the wall facing the scanners. Which of these is the better option and which (if any) will have the least amount of db loss?
BNC faceplate with 4 BNC connectors (meaning the multicoupler is BEHIND the faceplate) or...
... a faceplate with 1 BNC connector (meaning the multicoupler is in FRONT of the faceplate) this option would be preferred because the moulticoupler is active and requires power.
or a third option would be to have a nifty face plate that doesn't require the BNC connectors at all and just has a "cosmetically pleasing" alternative such as a downward facing hole that the coax runs straight through.
If the third option exists, can you point me to a link? Will having a faceplate with BNC connector cause signal loss?
Thanks!
Thanks!
