Coax next to electric
KO4IPV
Is there a problem running LMR 400 coax down from roof antenna next to a common electric wire twin run down wall entering room ? Could there be any type of static causation?
Hiding in a coffee shop.
Could be if there is something in your home that generates a lot of electrical noise. Ideally the electrical circuit should be in conduit or romex inside the wall, so there should be some separation. Keeping some space between them is a good idea.
KO4IPV
Well this is Florida and conduit or Romax is not code here , however I will try to separate them somehow
jcop225
Radio Zoomer
Boston, MA
R56 (Motorola's installation standard) states that there should be a minimum of 2" separation between RF cables and power cables or data cables.
buddrousa
As a low voltage installer code states do no run next to live AC as you could get 120 Volts AC inducted on your low voltage / coax.
I am never closer than 12 inches or cross at 90 degrees in a horseshoe over the AC.
