jcmios
For a 75ft radio to antenna which should I use RG-8/U or RG8-X? Whats the advantage or gain?
Thank you
Jim
Thank you
Jim
jcmios said:For a 75ft radio to antenna which should I use RG-8/U or RG8-X? Whats the advantage or gain?
Thank you
Jim
jcmios said:I should have used the worf benifit not gain, sorry.
Jim
2 miles from the repeater with 45 watts, any antenna is overkill.jcmios said:I have one Motorola CM300 VHF and another in UHF, our frequecies are mostly clustered in the 147.0 to 152.0 and 456.0 to 472.0. As for the antennas I am still shopping and open to sugestions, they will be mast mounted on opposite ends of my roof. I am on a budget but then who isn't? Both radios are 45watts and I live on the highest ground in the county with nothing but corn and soybeans for obstructions and about 2 miles from the main repeater and base.
Jim
Rubber duckie on the back of the radio should be fineN_Jay said:2 miles from the repeater with 45 watts, any antenna is overkill.
