I have a 67' 14 ga. wire strung up and connected to a Winradio balun 'longwire antenna adapter' Using RG8X from the BNC jack on the balun into the house to the IC-R75.
Yesterday when checking the BNC connector of some new coax connected to the Winradio balun with my Fluke meter, the center conductor and the outer shield of the coax have continuity.
The coax does not have continuity between the sheild and center when disconnected.
The Winradio balun is the source - it has a closed circuit from center to outer of the BNC jack and in fact the center has continuity to the whole outer metal housing of the balun.
I opened the balun up and it appears to have been designed that way.
Shouldn't the outer always be seperate electrically from the inner conductor or is this irrelevant with a single wire type antenna? It seems this would increase noise into the receiver...?
