Homepatrol2, Workman T601 discone on 20 ft mast, now what type coax? Run will be less than 50 ft.
Antenna has a SO239 connection, Hp2 has SMA connection.
. As I posted above Rg6 quad shield has decent loss figures which is fine for 800mhz, since it was designed for Uhf and above. :wink: 73, n9zasMainly between 154 mhz and 800mhz.
. The proper way would be use a Rg6/ F59 connector with a pl259 adapter at the antenna, and f59 male/ female/Sma adapter for your scanner. Be sure to use coaxial sealant at the antenna also. 73, n9zasWith the antenna having a SO239 connector and the Hp2 being SMA, could the Rg6 have connectors installed to work with this?
Which is better then, LMR 400, or Rg6 to monitor 800mhz?
I use f to pl259 and f to n adapters to run rg6 to antennas... I did a test of a 30' setup using the above vs lmr 400 with a pl259 and another with an n conn. At the end and i couldnt see ant difference between the 3 using some 800 control channels....
