Cobb P25 TRS update
AndrewC75
Kennesaw, GA
I started watching the Cobb P25 TRS last night with Unitrunker. Today, I saw two radios affiliate with the system and use two talkgroups on two previously unidentified voice channels:
Radios:
TGs:
2001 - Unknown use
2002 - Unknown use
Voice channels:
860.9875
868.3000
It looks like the control channels for the system are currently set up as 856-859.2125, but several of those freqs are still being used as voice channels for the analog system. Currently, the control channel is 859.2125, and it hasn't rotated to another freq yet.
AndrewC75
Kennesaw, GA
Looks like they are adding channels today. Two additional VC's popped up this afternoon on Unitrunker:
866.8875
867.5500
and the talkgroups listed above are also seeing some activity this afternoon.
BANDIT
Gainesville, Ga
If you will run Pro86com on the system you can see all of the new channels. Its all in the control channel data stream now.
BANDIT
Gainesville, Ga
Oh, and I forgot try truning on the log function of unitrunker also and you can see whats going on on the control channel. Be careful tho as it logs as long as Unitrunker is runing and can get quite large.
