Cobra 2000GTL Mod Removal Questions - Replacement Part Questions
langmikea
I am rebuilding a Cobra 2000GTL. I have replaced all electrolytic caps and removed the obvious modifications. I am left with some questions.
1) Are the bottom-side components in photo 1 original?
  • Resistor
  • Capacitor
  • Jumper
  • Sleeved parts (two)
2) The following parts are missing topside; are they needed?
  • C82 0.047uF Cobra lists the ref des and value, but not their internal part number; why?
  • C115 0.0047uF
  • D35 1S2687D On order
  • D51 1S1588 On order
  • D52 KB262 Replace with two 1N4148 in series
  • R44 8.2K
3) Are there other components that I should check for? Are there some parts that typically changed, as opposed to being added or removed?
Thanks!
Mike
