Cobra 75WXST odd behavior
IQ_imbalance
Just installed a used cobra 75WXST. Had a good SWR on my antenna (<1.2 on channel 19) and everything seemed fine for a couple of days. Today however….was driving along and it sounded like a signal broke squelch and then stayed keyed (noise and signal meter showing strong reception). Problem is…it never stops. Shouldn’t be my vehicle as I had a perfectly good baseline for several days (unless something broke I suppose!). Has anyone else run into this kind of thing?
IQ_imbalance
I'll answer my own question....looks like the cheap 12V to 5V power supply i use to supply another radio in the vehicle is causing the noise. Discovered -that- by accident, but it's a place to start.
  • Like
Reactions: wtp
IQ_imbalance
Probably doesn't help that it's in the footwell and subject to the occasional kick (which might explain the sudden onset). I'm going to trim any extra wire and try doing a better job of securing it. I have a few ferrite snap on chokes that I can throw on there as well.
FKimble
Newnan, GA
Yea, every time I put my cell phone on the cig charger, my FM radio would get scratchy. Unplug phone or charger, back to normal.
Frank
gary123
A lot of these cheap 12v-5v adapters make all kinds of noise. There is no filtering in them at all. The cable from the adapter to the device acts like an antenna. The only practical solution is to get a high quality adapter with the noise filtering choke on the line. Do your R&D there are cheap Chinese adapters that appear to have a choke but all it is is a plastic block with nothing in side it.
