Cobra soundtracker with Solarcon a99 antenna
jakubman1
Please send that antenna back, it works worse than a tiny mobile antenna and you probably won't get 3 miles out of it. A Solarcon is 10X the antenna.
i know its not a good antenna but i just want to try it and see if he can here me from down the road. I got my Solarcon from direct depot for like 117$
DeeEx
New England
I made contact with someone about 5 miles away buut he said that i sounded far away . Is this normal?
Make sure your mic is clean, you aren’t speaking into solid plastic or metal (manufacturers sometimes don’t line any holes up with the mic element inside), or that it’s not jammed with dry saliva or bits of food.
Turn up your modulation if possible; a local shop can do it if you don’t have the ability. Just please don’t cut the modulation limiter, also known as “clipping”, or allow a shop to do that. It won’t be doing anyone any favors. You will be transmitting harmonics and annoying other users, and possibly anyone nearby with a device that contains a speaker.
jakubman1
thank you i will find a place that can do this. How much is the going rate?? I dont want to get ripped off
slowmover
Fort Worth
“Others have inferior CB Radio installations”.
— Take this as working assumption.
IMO, the goal of one’s own installation — base or mobile — is to try and overcome (compensate) for what the other guy has. Some extra power and decidedly better ears.
It’s not bragging rights. It’s in establishing and maintaining comms for as long as is reasonable (mobile, the time involved may be very short).
As to the radio, ask if it sounds clean. If okay, go on to next item. I’d want to improve the antenna system (station ground, also) even if more work, but has greater effect.
Below is an example.
