Cochrane Ontario Fire
RuBBerHeaD
Ontario
OK thank you. I did a scan and got a fire test on this freq 154.130. I will monitor it more.
IdleMonitor
The Ottawa Valley - Eastern Ontario
Likely Iroquois Falls or Black River-Matheson areas.
Iroquois falls is already in the database Cochrane District County, Ontario (ON) Scanner Frequencies and Radio Frequency Reference Perhaps they have a seperate PL tone for both areas.
RuBBerHeaD
Ontario
OK thank you. I guess Iroquois Falls reaches Cochrane because it was crystal clear on the 9am check for Cochrane. lol
Radioguy789
Ontario
The Cochrane FD is on the Spectrum Digital CAP+ system. You will only hear the page call come through on there old VHF channel.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I've noted a few frequencies around Nipissing that are showing as Capacity Plus and are licensed to Spectrum:
164.925 cc 4 cap+ spectrum powassan
165.81 cc 4 site 2
These might be part of a much larger system that Cochrane Fire is on.
Would seem to be a part of TAFL Search Results
I'd try 162.270 and 164.370.
If they're part of a Cap+ system, one should be beaconing away every few seconds.
Radioguy789
Ontario
Yes they are on the CAP+ system and they are digital and the only way you can hear them is you will need a scanner that can do TRBO like the BCD 996P2. Or if you use DSD+ Fast Lane on your computer with a scanner hooked up to it.
You can try: 162.270 & 164.370.
RuBBerHeaD
Ontario
165.81 cc 4 site 2
ok thank you
