Coconino County Sheriff frequencies.
marlin39a
Paulden, AZ.
I’ve programmed all the listed frequencies, and am receiving nothing. I’m using a BC895XLT, and it works fine. Has the CCSO gone to a new system?
cellphone
Ahwatukee, AZ (Phoenix)
I was there about 3 weeks ago, and the VHF frequencies were alive and well for Coconino County Sheriff. I can't imagine things have changed that quickly, but you never know these days. The DB should be current unless there was a major change in the last few weeks.
marlin39a
Paulden, AZ.
I only do analog here. Here is a link to the trucked system. Just asking if anyone local can verify.
DonWetter
I have not noticed anything different on the analog posted CCSO frequencies. I am listening to them now from my Northern AZ home location. Flag PD et al are on trunked system although I am not hearing that much NAU traffic for a while.
DonWetter
I usually listen to 155.49 and 155.835. I suggest not using any CTCSS tones due to the varied location of the repeaters . Perhaps you are missing transmissions due to your use of a repeater tone far from your location.
KB7MIB
Peoria, AZ.
Can you confirm that you can receive other active frequencies in your area? Fire departments, DPS, ADOT, AZ Game & Fish, Coconino (Prescott, Kaibab) National Forest, Hams, aircraft, businesses?
What antenna are you using? If it's outdoors, when was the last time you inspected it and the feedline? Do you have a volt-ohm meter or an antenna analyzer to test the coax and the antenna?
John
Peoria
marlin39a
Paulden, AZ.
Thanks, John. I get all of Yavapai County, Flagstaff DPS, Williams PD, GCR railroad. I used to get CCS, but no more.
